Set up an OAuth 2.0 HTTP connection to inSided
inSided documentation: API guide , Authentication
integrator.io does not yet offer a built-in connector to inSided, but you can integrate with the API by setting up a universal HTTP connection with the OAuth 2.0 authentication type, as demonstrated below:
A. Set up an HTTP connection
Start establishing an HTTP connection to inSided in either of the following ways:
    – or –
B. Edit HTTP application details
This article is concerned only with the settings needed for inSided connections. For complete field documentation, see Set up an OAuth 2.0 HTTP connection.
Configure HTTP headers: Enter the name content-type and the value application/x-www-form-urlencoded.
Base URI: Paste the URL where you sign in to your inSided account – for example,
https://api2-us-west-2.insided.com.
Media type: Accept the default value, JSON.
C. Configure auth settings
Continuing in the Create connection pane, select OAuth 2.0 for the Authentication type. The settings then become specific to OAuth 2.0 connections:
Grant type: Select Client credentials, as required by inSided.
iClient: Assuming you haven’t yet established an inSided iClient (token ID-secret pair), click the + button to create one . Enter an identifiable Name along with the Client ID and Client secret from your inSided account. Click Save & close to add the iClient to your integrator.io account and select it for this connection.
Access token URL: Paste the same value you entered for the Base URI, above, followed by /oauth2/token.
Client authentication: Select Send as basic auth header.
Header name: Accept the default value, Authorization.
Scheme: Select Bearer.
D. Save, test, and authorize
  • Save & authorize – click this button to test the connection, commit the new connection so that it will be available to all integrations for your account (and applied to the current source or destination app, if you created it within a flow)
  • Cancel – click this link to exit connection creation without saving
E. Integrate with inSided
Then, when creating a flow step (such as an export, import, or lookup) to inSided, start by selecting an HTTP application, and then choose your inSided connection for it.
