Set up a connection to Pricefx
Pricefx is a cloud-based pricing software platform that helps businesses optimize pricing, manage quotes, and improve profitability.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings:
Setting Instructions
Name your connection *
Base URL * Enter your Pricefx base URL. For example, if your account is https://test.pricefx.com/pricefx, then enter test.pricefx.com.
Username * Enter your Pricefx account username.
Partition * Enter your Pricefx account partition. For detailed information, see Partitions.
Password *
Enter your Pricefx account password.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text.
Additional references
