Authorize.net documentation: API Guide, Authentication
A. Set up a Authorize.net connection
Start establishing a connection to Authorize.net in either of the following ways:
In the resulting Application list, select Authorize.net.
B. Supply required Authorize.net account information
At this point, you’re presented with a series of options for providing Freshworks CRM authentication.
Account type (required): Select the environment for the connection (Production or Sandbox).
API login id (required): Enter the unique API Login ID. The API Login ID is provided in the Merchant Interface and must be stored securely. The API Login ID and Transaction Key together provide the merchant authentication required for access to the payment gateway.
Transaction key (required): Enter the unique transaction key. The merchant Transaction Key is provided in the Merchant Interface and must be stored securely. The API Login ID and Transaction Key together provide the merchant authentication required for access to the payment gateway.
- Log in to your Authorize.net account.
- Click Settings > API Credentials & Keys.
- From this page you can copy your API Login ID and generate New Transaction Key or a New Signature Key.
C. Edit advanced Authorize.net settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Authorize.net connection.
D. Test the connection
Once you have configured the Authorize.net connection, you have a few options for continuing:
