Set up a connection to PrestaShop
PrestaShop is a freemium, open source e-commerce platform. The software is published under the Open Software License (OSL)
Setting Instructions
Name your connection *
Mode *
Select one of the following options:
  • Cloud to connect to a publicly accessible server application.
  • On-premise to connect to a server that is publicly inaccessible and has an integrator.io agent installed on it
Agent *
Select an agent from the list.
To connect to an on-premise application, integrator.io requires that an agent be installed on a networked computer. An agent is a small application that allows you to connect to data behind your firewall. When installing an agent, you will specify a unique access token, which then populates the Agent drop-down list. The installed agents connect to integrator.io and establish a reverse SSH tunnel, allowing secure communication without the need to whitelist integrator.io IP addresses in your firewall settings. A single agent can be used by multiple different connections.
Store URL*
Enter your PrestaShop account store URL.
For example, if your login URL is http://localhost/prestashop/admin12345, then enter http://localhost/prestashop.
API key*
Enter your PrestaShop API key.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom auth universal connector documentation.
How to retrieve API key
  1. Sign in to your PrestaShop store’s back office.
  2. Navigate to Configure > Advanced parameters > Webservice.
  3. In the Webservice page > Configuration section > switch the Enable PrestaShop’s webservice toggle to Yes.
  4. Click Save.
  5. Click Add new webservice key.
  6. Review the Permissions, and select the Scopes.
  7. Click Generate and Copy the API key.
