Set up an OAuth 2.0 connection to Pipedrive
Pipedrive is a sales CRM designed to help teams track leads and deals through a visual pipeline, automate follow-ups, and close more sales efficiently.
Setting
Instructions
Name your connection *
API version
Select your Pipedrive account API version (v1 or v2).
Subdomain *
Enter your Pipedrive subdomain. For example, if https://na3.pripedrive.com" is the URL then na3 is your subdomain.
Auth type *
Select OAuth 2.0 as the authentication type for this connection (the Token option is described separately).
OAuth 2.0 client *
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit (pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
dataLoad.svg​​
  1. Sign in to your Pipedrive developer account.
  2. Navigate to Developers hub > Create an app.
  3. Fill in the necessary details.
  4. In Callback URL, enter the Celigo integrator.io redirect URL.
  5. Click Save.
  6. The Client ID and Client Secret are displayed once you save your app details.
Additional references
