Fulfillment.com is an e-commerce service provider that allows you to reduce shipping costs and expand into new markets to outsource your order.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required * authentication settings.
Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections that you’ve created. |
Client ID * |
Enter your Fulfillment.com client ID. Contact Fulfillment.com support to retrieve the client ID. |
Username * |
Enter your Fulfillment.com account username. |
Client secret * |
Enter your Fulfillment.com client secret. Contact Fulfillment.com support to retrieve the client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your client secret. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Password * |
Enter your Fulfillment.com account password. Multiple layers of protection, including AES 256 encryption, are in place to keep your password. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
