Set up a connection to Yotpo
Yotpo is an e-commerce marketing platform that helps brands win customers with reviews, SMS marketing, subscriptions, loyalty, and referrals.
Setting
Instructions
Name your connection *
API type *
Choose your Yotpo API type:
  • UGC: Collect, manage, and display user-generated content like reviews, ratings, photos, and Q&A to build trust and drive conversions.
  • Core: Manage Yotpo account settings, stores, authentication, and platform-level resources to support and configure Yotpo integrations.
  • Loyalty: Create and manage loyalty programs, points, rewards, and referrals to increase customer retention and repeat purchases.
UGC and Core API types:
App key *
Enter your Yotpo App key.
dataLoad.svg​​ How to retrieve the app key
Secret key *
Enter your Yotpo secrey key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your API secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the secret key
API version (Only for Core API)
Select your Yotpo API version (v1 or v3).
Loyalty API type:
GUID *
Enter your Yotpo GUID.
dataLoad.svg​​ How to retrieve the GUID
API key *
Enter your Yotpo API key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token authauth universal connector documentation.
How to retrieve the app key and secret key
  1. Sign in to your Yotpo account.
  2. Navigate to Settings > General settings > API credentials.
  3. Copy the App key.
  4. Click Get secret key. You'll receive a verification code to your registered email.
  5. Enter the Code and click Submit.
  6. Copy the Secret key.
How to retrieve the API key and GUID
  2. Navigate to Settings > General settings > Integrations.
  3. Copy the API key.
  4. Copy the GUID.
Additional references
