Kantata (formerly Mavenlink) software tools help organizations conduct business online, understand their productivity, and take strategic actions to improve profitability.
This video demonstrates creating a Kantata connection.
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Kantata.
To add an OAuth 2.0 client and configure your credentials, click the plus (+ ) button. Click the edit ( |
This article is concerned only with the settings needed for creating OAuth 2.0 client for Kantata. For complete field documentation, see Create a new iClient.
Sign in to your Kantata account.
Navigate to Settings > API > API settings page.
Click View your account’s registered applications.
On the resulting OAuth applications page, click Register a new Kantata OX application.
Enter Name.
Paste your integrator.io Callback URL.
Click Save.
Copy the Kantata OX application ID for the Client ID and the Secret token for the Client secret.
Name (required): Enter the required iClient name.
Client ID (required): Enter client ID (retrieved from the above section).
Client secret (required): Enter client secret (retrieved from the above section). Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s client secret safe. When editing the iClient at any point, you must enter the secret value again; it is stored only when the connection is saved and never displayed as text.
Click Save.
