Set up a connection to Maximo
IBM Maximo is an enterprise asset management (EAM) platform that helps organizations monitor, manage, and maintain physical assets throughout their lifecycle.
The Maximo connector is in BETA and may be subject to changes.
Setting Instructions
Name your connection *
Mode *
Choose your Maximo account mode (either Cloud or On-premise).
Base URL *
Enter your Maximo account base URL:
  • Cloud: If your Maximo account base URL is https://celigo1.maximo.ibmcloud.com/maximo/oslc ,then https://celigo1.maximo.ibmcloud.com is the subdomain.
  • On-premise: If your Maximo server URL is http://localhost:7001/maximo/oslc, then http://localhost:7001 is the subdomain.
Agent *
Choose your Maximo account agent. For more information, see Install the agent.
Username *
Enter your Maximo account username.
Password *
Enter your Maximo account password.
Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
API key *
Enter your Maximo API key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API key
Public URL *
Enter your Maximo public URL.
  1. Sign in to your Maximo account.
  2. Click Create API key.
  3. Enter a Description.
  4. Enter an Authentication token expiry.
  5. Select the applicable Permissions.
  6. Click Submit.
  7. Copy the API key.
Additional references
