Gender is an AI-powered platform that predicts the gender of a name or email address.
API key * |
Enter your Gender API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
