Kickflow is a workflow automation tool that helps companies automate approval processes.
| Setting | Instructions |
| Name your connection * |
Access token * |
Enter your Kickflow access token. Multiple layers of protection, including AES 256 encryption, are in place to keep your access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
- Sign in to your Kickflow account.
- Navigate to your Profile > Access token settings.
- Click Create access token.
- Enter a Name.
- Click Create.
- Copy the Access token.
