Set up a connection to Discourse
Discourse is an open-source discussion platform designed for building vibrant online communities through forums, Q&A, and long-form conversations.
The Discourse connector is in BETA and may be subject to changes.
Setting
Instructions
Name your connection *
Hostname *
Enter your Discourse account hostname. For example, if your Discourse account URL is https://celigo1.discourse.group/, then celigo1.discourse.group is the hostname.
API username *
Enter your Discourse API username.
How to retrieve the API username
API key *
Enter your Discourse API key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API key
How to retrieve the API username and API key
  1. Sign in to your Discourse account.
  2. Navigate to Admin > Advanced > API keys.
  3. Click New API keys.
  4. Enter a Description.
  5. Select the applicable User level. For more information on how to configure an API key, see Create and Configure an API key.
  6. Select Single user.
  7. Enter the User details.
  8. Select the applicable Scopes.
  9. Click Save.
  10. Copy the User (API username).
  11. Copy the API key.
