Set up a connection to PeopleStrong
PeopleStrong is a leading human capital management (HCM) SaaS platform in the Asia Pacific region, offering AI-powered solutions across the entire employee lifecycle.
The PeopleStrong connector is in BETA and may be subject to changes.
Setting
Instructions
Name your connection *
Subdomain *
Enter your PeopleStrong account subdomain. For example, if your URL is https://s2demo-admin.uat.peoplestrong.com, then s2demo-admin is your subdomain.
Client ID *
Enter your PeopleStrong client ID.
Realm ID *
Enter your PeopleStrong realm ID.
API key *
Enter your PeopleStrong API key.
Client secret *
Enter your PeopleStrong client secret.
Secret key *
Enter your PeopleStrong secret key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your secret key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom, universal connector documentation.
