Xentral is a cloud-based ERP platform designed for small and medium-sized enterprises, streamlining operations across order management, inventory, finance, and production.
API version |
Select your Xentral account API version (either v1 or v2). |
Xentral ID * |
Enter your Xentral account subdomain. For example, if your Xentral account URL is https://celigo1.xentral.biz, then celigo1 is the subdomain (Xentral ID). |
Token * |
Enter your Xentral account token. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Xentral account.
Navigate to Profile > Account settings > Developer settings >Personal access tokens.
Click + Create token.
Enter a Name.
Click Create token.
Copy the Token.
