Checkr is a technology company that provides background check services for businesses. It helps companies screen potential employees, contractors, or gig workers by automating and simplifying the background check process.
Environment * |
Select your Checkr account environment:
API key * |
Enter your Checkr API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Checkr account.
Navigate to Account > Developer settings.
Click Create key.
Select Secret key.
Copy the API key.
