The Microsoft Active Directory has two form views—Simple and SQL—that you can use to export data.
Simple view: Enables you to easily view and specify the resource, columns, and operations to filter and export data. This simple option is helpful if you're not very familiar with SQL and would like to
view all the resources and related options available
make UI selections rather than write SQL queries to export data
SQL view: Enables you to quickly write SQL queries. The SQL option is helpful if you're a technical user familiar with SQL and would like to
use SQL programming rather than the graphical user interface (GUI) for quicker database interactions
write SQL queries including complex ones to export data
The export settings under the What would you like to export? section differ in Simple and SQL view. Any settings you configure in this section is saved in that view only. If you switch views, this data is cleared. For example, if you switch from SQL to Simple view, then after the switch, the data in the SQL view is cleared. But, you can open the export and select the SQL view to access the most recently saved version of the data.
Enter all the required * fields in the sections below.
Settings |
General |
Name your export * |
Provide a clear and distinguishable name. You will have the option to choose this export throughout integrator.io, and a unique identifier will prove helpful later when selecting among a list of exports/lookups that you’ve created. |
Description |
Describe your export so that you and others can quickly understand its purpose. Be sure to highlight any nuances that a user should be aware of before using this import in a flow. As you make changes to the resource, be sure to keep this description up to date. |
Connection * |
Select the connection if you have an existing Microsoft Active Directory connection. If you want to create a new connection, see Set up a connection to on-premise Microsoft Active Directory. |
What would you like to export? (Simple view) |
Resource * |
Select a resource from the list. For more information, see Microsoft Active Directory tables & parameters. |
Select columns |
By default, all the columns for the resource are selected, and the number of selected columns is shown. If you want to select specific columns or review columns, click Select columns. In the Configure columns page that opens, based on your requirements,
Filtering conditions |
To filter records, use the logical and conditional operators. Logical operators: Use any of the following logical operators to define rules for data:
If you want to exclude all records that belong to a subsidiary company, select NOT. You can also select AND or OR to create filters that combine multiple rules for your filtration criteria. AND filters records that fit all listed rules in the group. OR filters records that fit any listed rules in the group. Conditional operators: Choose any of the following operators for the selected column. Enter any required fields for a specified operator.
What would you like to export? (SQL view) |
SQL query * |
Write the SQL query to retrieve records based on your requirements. Tip
Configure export type |
Export type * |
Select one of the following export types:
After you configure the required settings, click Preview to check the export. If the SQL query is not executed successfully, revise the Query or Export type values. Then, click Save.
These export settings are optional, and typically don't have to be configured. However, if required in your scenario, you can configure these settings.
Optional sections/settings |
Would you like to group records? |
Group records by fields |
Mock output |
Mock output |
Advanced |
Page size |
See Choosing the right page size in Fine-tune integrator․io for optimal performance and data throughput |
Data URI template |
When your flow runs but has data errors this field can be really helpful in that it allows you to make sure that all the errors in your job dashboard have a link to the original data in the export application. Use a handlebars template to generate the dynamic links based on the data being exported. For example, if you are exporting a customer record from Shopify, you would most likely set this field to the following value |
Do not store retry data |
Check this box if you do NOT want integrator.io to store retry data for records that fail in your flow. Storing retry data can slow down your flow's overall performance if you are processing very large numbers of records that are failing. |
Override trace key template |
If this field is set, you will override the platform default trace key field. integrator.io uses the trace key to identify a unique record. You can use a single field such as |
