Workday is an enterprise management cloud platform that provides solutions for finance, HR, spend management, and planning.
Celigo provides the following two connectors to connect to Workday:
Workday: This new connector supports primarily SOAP APIs (via SQL queries) and has more options to better integrate with Workday. See the instructions below to set up a connection using the new Workday connector.
Workday (HTTP): The previous Workday connector renamed to Workday (HTTP), supports primarily REST APIs. Set up a connection using the Workday (HTTP) connector.
Name • |
Base URL • |
Enter your Workday account base URL To get the base URL: |
Tenant ID • |
Enter your Workday tenant ID. For example, if your Workday tenant URL is https://impl.workday.com/sample_company/d/home.html, then sample_company is your tenant ID. |
Connection type • |
SOAP is selected, by default, as the protocol to be used by web services. |
WSDL Version |
Select the WSDL version. Default is v36.1. Available versions: v42.1, v41.1, v40.2. |
Service |
Choose one or more Workday web service that you'd like to connect to. By default, all the web services are selected. |
Auth scheme • |
The authentication mechanism to connect to Workday. Currently, we support only Basic authentication. |
Username • |
Enter your username to log in to Workday. |
Password • |
Enter your password to log in to Workday. |
