Set up a connection to Elmo Software
Elmo Software is a cloud-based end-to-end HR and payroll platform that automates and streamlines the full employee lifecycle, from hiring to retiring.
The Elmo Software connector is in BETA and may be subject to changes.
Setting
Instructions
Name your connection *
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Elmo Software.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit (pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
