Set up a connection to Shippit
Shippit is a cloud-based shipping and fulfillment platform that helps retailers automate and optimize their delivery processes.
Setting
Instructions
Name your connection *
Environment *
Select your Shippit environment:
  • Production: If your account URL is https://app.shippit.com.
  • Staging: If your account URL is https://app.staging.shippit.com.
API key *
Enter your Shippit API key.
dataLoad.svg​​How to retrieve the API key
  1. Sign in to your Shippit account.
  2. Navigate to Settings > Integrations > API keys.
  3. From Store search, select your Store.
    Each store is associated with a distinct API key. From Store search, you can switch between the stores.
  4. Copy the API key.
