Groupon is an e-commerce platform that connects subscribers with local merchants by offering discounted deals on goods, services, and activities.
The Groupon connector is in BETA and may be subject to changes.
API type * |
Choose your Groupon API type:
Supplier ID * |
Enter your CommerceInterface supplier ID. |
Token * |
Enter your Groupon Goods token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
