Metabase is an open-source business intelligence tool that allows users to explore, visualize, and share data through dashboards, charts, and reports using a simple interface.
The Metabase connector is in BETA and may be subject to changes.
| Setting | Instructions |
| Name your connection * |
| Mode * | Choose your Metabase account mode (Cloud or On-premise). |
| API key * |
Enter your Metabase API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this key again; it is stored only when the connection is saved and never displayed as text. |
| Mode: Cloud | |
| Instance URL * |
Enter your Metabase account instance URL. For example, if your URL is |
| Mode: On-premise | |
| On-premise agent * | Choose your Metabase account agent. For more information, see Install the agent. |
| Instance URL * |
Enter your Metabase server instance URL. For example, if your URL is |
