Set up a connection to Starshipit
Starshipit is a shipping and fulfillment automation platform designed to streamline logistics operations for e-commerce businesses.
Setting
Instructions
Name your connection *
API key *
Enter your Starshipit API key.
Subscription key *
Enter your Starshipit subscription key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your subscription key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the subscription key
How to retrieve the API key and subscription key
  1. Sign in to your Starshipit account.
  2. Navigate to Settings > API.
API key
  1. Click Generate.
  2. Copy the API key.
  3. Click Save.
Subscription key
  1. Click Generate.
  2. Copy the Subscription key.
  3. Click Save.
