Loftware provides enterprise labeling and artwork management solutions.
The Loftware connector is in BETA and may be subject to changes.
Mode * |
Choose your Loftware account mode (Cloud or On-premise). |
Subscription key * |
Enter your Loftware subscription key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Agent * |
Choose your Loftware account agent. For more information, see Install the agent. |
Instance URL * |
Enter your Loftware server instance URL. For example, if your local host is http://localhost:3000, then |
Sign in to your Loftware Control Central account.
Navigate to Integrations > Cloud integrations.
Click Add and enter a developer's Name. For detailed information, see Cloud integrations.
Copy the Integration key and click Save.
Sign in to your Loftware developer account.
Navigate to Products > Loftware Cloud.
Enter a Subscription Name and click Subscribe.
Navigate to APIs > Developer sign up API v1.
Click Try it. The Developer sign-up panel appears.
From Subscription key, select your Primary key.
In Parameters, paste the Integration key retrieved from step 4 and click Send.
Copy the OCP-APIM-subscription-key.
