Parallel is an AI infrastructure platform that helps AI agents perform accurate, real-time web research.
API key * |
Enter your Parallel API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Parallel account.
Navigate to Settings > API keys.
Click + Create new API key.
Enter a Key name.
Click Create new key.
In API key value, click the Eye icon. The API key details message opens.
Copy the API key.
