Klaviyo is a marketing automation platform designed to help businesses grow by leveraging data-driven insights to create personalized and targeted email and SMS marketing campaigns.
| Setting | Instruction |
| Name your connection * |
| API type * |
Choose your Klaviyo API type:
| Private key * |
Enter your Klaviyo private key. For detailed information on retrieving the private key, see Keys. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s private key safe. When editing this form later, you must enter this key again; it is stored only when the connection is saved and never displayed as text. |
| Public key * |
Enter your Klaviyo public key. For detailed information on retrieving the public key, see Keys. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s public key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
| Revision * | Enter your Klaviyo API endpoint version in YYYY-MM-DD format. |
