Best Buy is a multinational retailer that sells consumer electronics, appliances, and related services through its retail stores and online platform.
The Best Buy connector is in BETA and may be subject to changes.
API key * |
Enter your Best Buy API key provided by the Best Buy team. For more information, see API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
