Set up a connection to AFAS ERP
AFAS ERP is a cloud ERP solution that integrates finance, HR, payroll, procurement, and project management into one unified system.
The AFAS ERP connector is in BETA and may be subject to changes.
Setting
Instructions
Name your connection *
API type *
Choose your AFAS ERP API type:
  • Profit: Access and update financial, HR, and operational data to automate core ERP workflows and enterprise integrations.
  • SB: Manage sales, service, and business processes in the cloud to streamline operations and data synchronization.
API type: Profit
Environment *
Select your AFAS ERP account environment:
  • Accept: if your account URL is https://restaccept.afas.online/
  • Cursus: if your account URL is https://restcursus.afas.online/
  • Production: if your account URL is https://rest.afas.online/
  • Test: if your account URL is https://resttest.afas.online/
Environment number *
Enter your AFAS ERP environment number. For example, if your environment name is C12345AA, then 12345 is your environment number.
Auth type *
Select your AFAS ERP account authentication type (either OAuth 2.0 or Custom).
API key * (for Custom auth type only)
Enter your AFAS ERP API key.
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by AFAS ERP.
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit (pencil.svg ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
API type: SB
Domain *
Enter your AFAS ERP account domain. For example, if your account URL is https://test123.afasfocus.nl, then test123 is the domain.
Customer environment *
Enter your AFAS ERP customer environment. For example, if your account URL is https://test123.afasfocus.nl/scope, then scope is the customer environment.
Auth type *
Select your AFAS ERP account authentication type (either OAuth 2.0 or Token).
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you via email by AFAS ERP.
Token *
Enter your AFAS ERP token.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the custom universal connector documentation.
  1. Sign in to your AFAS ERP portal
  2. Navigate to General > Management > App connector.
  3. Click New.
  4. Enter a Description.
  5. Navigate to Authentication type.
  6. Select OAuth.
  7. Select the Authorization group.
  8. Select the required Get and update connectors. For more information, see Set up your own connection.
  9. Copy the Client ID.
  10. Copy the Client secret.
Additional references
