Storecove is an e-invoicing platform that helps businesses send, receive, and process electronic invoices across global networks in compliance with tax regulations.
The Storecove connector is in BETA and may be subject to changes.
Environment * |
Select your Storecove account environment type (Production or Sandbox). |
API key * |
Enter your Storecove API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Storecove developer account.
Navigate to Settings > API keys.
Click Create new API key.
Copy the API key.
