Set up a connection to Mollie
Mollie is a payment platform that helps businesses accept and manage online and in-store payments easily.
Setting
Instructions
Name your connection *
Auth type *
Select your Mollie account authentication type (OAuth 2.0 or Token).
Auth type: OAuth 2.0
OAuth 2.0 *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Mollie.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Auth type: Token
Token *
Enter your Mollie token.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the token
Scope *
Scopes are OAuth 2.0 permissions that Mollie defines to limit access to your account.
  1. Sign in to your Mollie account.
  2. Navigate to Browse > Developers > API keys > Your apps.
  3. Click Create application.
  4. Enter the Name and Description.
  5. Enter the Celigo integrator.io Redirect URL.
  6. Click Save.
  7. Copy the Client ID.
  8. Copy the Client secret.
  2. Navigate to Browse > Developers > Access tokens.
  3. Click Create token.
  4. Enter a Description.
  5. Check the required Permissions.
  6. Click Save.
  7. Copy the Token.
How to configure scopes
  1. Click Scope.
    – or –
  3. Click Save.
Additional references
