Set up a connection to DeepL
DeepL is a translation platform that helps users translate text, documents, and websites accurately across multiple languages using advanced AI.
Setting
Instructions
Name your connection *
API version
Select your DeepL account API version.
Environment *
Select your DeepL API environment type (Free API or Pro API).
API key *
Enter your DeepL API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API key
  1. Sign in to your DeepL account.
  2. Navigate to API keys and limits.
  3. Click Create key +.
  4. Enter a Name.
  5. Click Save.
  6. Copy the API key.
Additional references
