Set up a connection to Airbrake
Airbrake is an error and performance monitoring tool that helps developers track, analyze, and fix issues in applications for improved reliability.
The Airbrake connector is in BETA and may be subject to changes.
Setting
Instructions
Name your connection *
API key *
Enter your Airbrake API key (Project key, user key, or user token).
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s key safe. When editing this form later, you must enter this key again; it is stored only when the connection is saved and never displayed as text.
