Zenefits documentation: API guide, Authentication
Additional reference: Supported Zenefits APIs
Zenefits is a human resource software focusing on payroll and health insurance coverage. It also has features for time tracking, onboarding and employee record-keeping, performance, well-being, and collaboration. Zenefits
Contents
- A. Set up a Zenefits connection
- B. Edit Zenefits application details
- C. Edit advanced Zenefits settings
- D. Test the connection
Start establishing a connection to Zenefits in either of the following ways:
In the resulting Application list, select Zenefits.
At this point, you’re presented with a series of options for providing Zenefits authentication.
App key (required): Enter the unique app key provided by Zenefits to retrieve your app key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
- Log in to your Zenefits account.
- On the dashboard, navigate to Company Profile > Custom Integrations.
- Unmask and copy the token. If none exists yet, click “Add Token” and select the required scopes to create a new token.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Zenefits connection.
Once you have configured the Zenefits connection, you have a few options for continuing:
