Looker is a business intelligence software and big data analytics platform that helps customers explore, analyze and share real-time business analytics easily.
This video demonstrates creating a Looker connection.
After you start the connection, configure it in the Create connection panel and complete all the required * authentication settings:
Client ID * |
Enter your Looker client ID. |
Instance URL * |
Enter your Looker instance URL. For example, if If your URL includes a port number, it should be specified as a part of the instance URL. For example, |
Client secret * |
Enter your Looker client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Looker developer account.
Navigate to Admin > Users.
Click Add users. The Adding a new user page appears.
Enter the user's Email ID.
Select Groups and Roles.
Click Save. You'll navigate to Edit user page.
Enter the required information and click Save.
From API3 keys, click Edit keys. The Edit user API3 keys page appears.
Click New API3 key.
Copy Client ID.
Copy Client secret.
