PandaDoc is an all-in-one document workflow automation platform that helps in creating, managing, and signing digital documents such as proposals, quotes, and contracts.
This video demonstrates creating a PandaDoc connection.
Auth type * |
Select OAuth 2.0 as the authentication type for this connection (the token option is described separately). |
API key * |
Enter the API key of your PandaDoc account. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your PandaDoc account.
Navigate to Profile settings > Integrations > API.
Copy API key.
