SAP Business ByDesign is a cloud ERP solution built for small- and mid-market businesses and delivers prebuilt processes for everything from finance and sales to product management and purchasing on a single, unified solution.
You can use this SAP Business ByDesign connector to create SOAP, Custom OData, or Analytics OData connections. To use the full functionality of your SAP connection when importing or exporting data, change the Form view to HTTP.
SAP Business ByDesign documentation: API guide, Authentication
Additional reference: Supported SAP Business ByDesign APIs
Note: This connection is compatible with the latest SAP Business ByDesign version, Aug 2021 – v.21.08.
Contents
- A. Set up an SAP Business ByDesign connection
- B. Describe SAP Business ByDesign connection
- C. Provide required SAP Business ByDesign account information
- D. Edit advanced SAP Business ByDesign settings
- E. Test the connection
- Watch: Connecting to SAP Business ByDesign
Start establishing a connection to SAP Business ByDesign in either of the following ways:
In the resulting Application list, select SAP Business ByDesign.
At this point, you’re presented with a series of options for providing SAP Business ByDesign authentication.
Tenant hostname (required): Enter the tenant hostname of your SAP Business ByDesign instance. For example, if https://recruit14.sapbydesign.com is your instance, then type recruit14 for this setting.
Username (required): Enter the username for your SAP Business ByDesign account.
Password (required): Enter the password for your SAP Business ByDesign account. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the SAP Business ByDesign connection.
Once you have configured the SAP Business ByDesign connection, you have a few options for continuing:
- Close – click to exit without saving any new changes
