PandaDoc documentation: API guide, Authentication
PandaDoc is an all-in-one document workflow automation platform that helps in creating, managing, and signing digital documents such as proposals, quotes, and contracts. For a list of supported endpoints, see Supported PandaDoc endpoints.
A. Set up a PandaDoc connection
Start establishing an OAuth 2.0 connection to PandaDoc in either of the following ways:
In the resulting Application list, select PandaDoc.
B. Edit PandaDoc application details
At this point, you’re presented with a series of options for providing PandaDoc authentication.
Application details
Authentication type (required): Select OAuth 2.0 from the drop-down menu.
iClient (required): Select the iClient pair that stores the client ID and client secret provided to you by PandaDoc. To add an iClient and configure your credentials, click the plus (+) button. Click the edit ( ) button to modify a selected iClient. Be sure to give the iClient a recognizable name for use in any other connections. Use the following steps to retrieve the client ID and client secret:
- Navigate to the PandaDoc Developer Console to register the OAuth application.
- Click Create application (or open the settings for an existing OAuth app).
- Enter the required fields to create a new application.
- Once the app is created, you can retrieve the Client ID and Client secret from the bottom of the settings form.
Redirect URL (read-only): Copy this integrator.io callback URL to provide directions to PandaDoc for where to go after authentication. (This URL should be whitelisted with the authorization server.)
https://integrator.io/connection/oauth2callback
C. Edit advanced PandaDoc settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the PandaDoc connection.
D. Test the connection
Once you have configured the PandDoc connection, you have the option to Save & authorize or Cancel your changes.
When you save the connection, PandaDoc allows you to sign in. Click Authorize.
