Quickbase is a no-code application development platform that allows citizen users to create custom applications.
This video demonstrates creating a Quickbase connection.
User token * |
Enter your Quikbase user token. Multiple layers of protection, including AES 256 encryption, are in place to keep your user token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Hostname * |
Enter your Quickbase hostname. For example, if your Quickbase account is located at |
App ID * |
Enter your Quickbase app ID. To find the app ID, navigate to your existing app or create a new app. The App ID appears at the end of the URL in the address bar. For example, if your app URL is If you create a new app, ensure you assign the new app to your user token. |
Sign in to your Quickbase account.
Click your profile name.
Navigate to My preferences > My user information > Manage user tokens.
Click + New user token.
Enter Name.
From Assign token to apps, select the required app.
Click Save.
Copy token.
