Review your subscription endpoints
Your integrator.io subscription defines how many flows, endpoints, and on-premise agents your account can use. You can check current usage against your entitlements at any time from your account settings. Use this to monitor consumption and request an upgrade before you reach a limit.
Note: Connections to the Celigo integrator.io API no longer count toward your endpoint entitlement. Previously, reaching the endpoint limit could block operations such as cloning templates, installing integration apps, or accessing flow errors through the API. This restriction no longer applies.
Prerequisites
  • You must be an account owner or administrator to access subscription details.
  • Endpoint usage data is available only on the 2024 license. If your account is on the 2022 license, usage data is not stored or displayed in integrator.io. Contact Celigo Support to discuss upgrading your license.
Review your entitlements
  1. Select your Avatar in the left navigation to open your account settings.
  2. Select Subscription.
  3. Review the entitlement summary, which shows:
    • Number of distinct flows run
    • Endpoints invoked
    • On-premise agents in use
  4. Select View next to any entitlement to see a detailed usage breakdown.
When you approach a limit, select Upgrade to request an increase.
