Set up a connection to Autopilot
Autopilot software helps to automate and personalize your marketing through the entire customer journey. Autopilot provides cloud marketing applications such as email, in-app engagements, SMS, and direct mail.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
Setting
Instructions
Name your connection *
API key *
Enter your Autopilot API key.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token auth universal connector documentation.
How to retrieve the API key
  1. Sign in to your Autopilot account.
  2. Navigate to Settings > Autopilot API.
  3. Click Generate.
  4. Copy API key.
Additional references
