MessageMedia is a business SMS and unified messaging service provider that helps businesses connect with customers. When you integrate MessageMedia with your CRM, it keeps your contacts, messages, and more in sync.
API key * |
Enter your MessageMedia API key. |
API secret * |
Enter your MessageMedia API secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your API secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic auth universal connector documentation.
Sign in to your MessageMedia account.
Navigate to Configuration > API settings.
Enter the API key label name.
Click Create new key to generate a new key and secret. The Create basic API key panel opens.
Click Create key.
7. Copy the new API key and secret.
If you do not copy your new API token now, you will need to create another API key and API secret the next time you need to retrieve them as plain text; they will not be shown again.
