Set up a connection to Breezy HR
Breezy HR is an applicant tracking system that helps companies streamline their staffing processes.
After you start the connection , configure it in the Create connection panel and complete all the required * authentication settings:
Setting
Instructions
Name your connection *
Email *
Enter your registered Breezy HR account email.
Password *
Enter your registered Breezy HR account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see  token auth universal connector documentation.
Additional references
