Segment is a customer data platform that helps you collect, clean, and control customers’ data.
This video demonstrates creating a Segment connection.
Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections that you’ve created. |
Write key * |
Enter your Segment write key. Multiple layers of protection, including AES 256 encryption, are in place to keep your write key. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Custom universal connector documentation.
Sign in to your Segment account.
Navigate to Connections > Sources > HTTP API server > Settings > API keys.
Copy Write key.
