monday.com is a cloud-based platform that powers teams to run projects and workflows. It is a simple but intuitive work operating system for teams to shape workflows, adjust to shifting needs, and create transparency.
monday.com documentation: API guide , Authentication
Currently, Celigo integrator.io does not offer a prebuilt connector to monday.com. However, you can integrate with the API by setting up a universal HTTP connection with token-based authentication.
Start establishing an HTTP connection to monday.com in either of the following ways:
From the Resources menu, select Connections. Then, click + Create connection at the top right.
– or –
While working in a new or existing integration , you can add an application to a flow simply by clicking Add source or Add destination/lookup.
The Create connection panel opens with required and advanced settings.
Mode (required): Select Cloud.
This article is concerned only with the settings needed for the monday.com connection. For complete field documentation, see Set up a token-based HTTP connection.
At this point, you’re presented with a series of options for providing HTTP authentication.
Base URI (required): Enter the monday.com base URI: https://api.monday.com/v2.
Configure HTTP header: Configure the HTTP header only when you are uploading files to monday.com
Media type (required): Select JSON.
Override media type for success responses: Accept the default value, Do not override.
Override media type for error responses: Accept the default value, Do not override.
In the Configureauthentication section, select and configure the authentication.
Auth type (required): Select Token.
Token (required): Enter the API token provided to you by monday.com. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API token safe. When editing this connection, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
Send token via (required): Select HTTP header.
Headername (required): Accept the default value, Authorization.
Headerscheme: Accept the default value, None.
Sign into your monday.com account.
Navigate to Profile > Account > Admin > API.
Copy your API token.
To create an API token, you can click Generate.
Expand the How to test this connection? section.
HTTP method: Select POST.
Once you have configured the monday.com connection, you have a few options for continuing:
Save – click to test the connection, commit the new connection so that it will be available to all integrations for your account
Save & close – click to test and save the connection and exit the Create connection panel
Close – click to exit without saving any new changes
Test connection – click to verify that your new connection is free of errors
