Octopus Deploy is an automated deployment and release-management platform that helps teams deliver applications reliably across cloud, on-premises, and hybrid environments.
Host URL * |
Enter your Octopus Deploy host URL. For example, if your instance name is |
API key * |
Enter your Octopus Deploy API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Octopus Deploy account.
Navigate to Profile avatar > Profile > My API keys > New API keys.
Enter the Purpose.
Click Generate new.
Copy the API key.
