Set up a connection to Channable
Channable is a feed management and PPC automation tool used to optimize and distribute product data across marketplaces and ad channels.
Setting
Instructions
Name your connection *
API token *
Enter your Channable API token.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the API token
Company ID *
Enter your Channable company ID.
dataLoad.svg​​ How to retrieve the company ID
Project ID *
Enter your Channable project ID.
dataLoad.svg​​ How to retrieve the project ID
How to retrieve the API token and company ID
  1. Sign in to your Channable account.
  2. Navigate to Company settings > Channable API.
  3. Click Generate token. For more information, see Authentication.
  4. Copy the API token.
  5. Copy the Company ID.
  2. Select a Project and navigate to Settings.
  3. Copy the Project ID.
