Set up a connection to Iterable
Iterable is a customer engagement platform that helps teams create, personalize, and automate cross-channel campaigns (email, SMS, push, in-app) to drive user activation, retention, and growth.
Setting
Instructions
Name your connection *
Region *
Select your Iterable account region:
  • Europe: if your account URL is https://app.eu.iterable.com
  • US: if your account URL is https://app.iterable.com
API key *
Enter your Iterable API key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API key
  1. Sign in to your Iterable account.
  2. Navigate to Integrations > API keys.
  3. Click New API key.
  4. Enter a Name.
  5. Select the API key Type. For more information, see Authentication.
  6. Click Create.
  7. Copy the API key.
