APIs vs. tools: how to choose
APIs and tools both execute logic in integrator.io, but they serve different purposes. Use this guide to decide which to build.
It is recommended to build reusable logic as a tool and if external access is required, create an API that invokes the Tool.
Quick decision guide
Use Case
Use Tool
Use API Builder
Reusable internal logic
Logic used in Flows or AI Agents
Expose endpoint to external systems
Need custom HTTP configuration (URL, headers, methods)
Need custom error responses
Require retries and queueing
✓ (in Flows)
Long-running process
✓ (in Flows)
Strict 2-minute timeout acceptable
Use a tool when
  • Logic is reusable across Flows, APIs, or AI Agents
  • The process runs internally within Celigo
  • You need Flow-level retries, queueing, or pause-on-error
  • The process may run longer than 2 minutes
  • You want to avoid unnecessary API call costs
Tools
  • Have one input and one output (JSON contract-based)
  • Do not support HTTP configuration
  • Do not customise error responses
  • Are context-aware (behaviour depends on where they run)
  • Require connection overrides at runtime
Connection overrides (tools only)
Tools require connection overrides at runtime.
  • The Tool defines required connection types.
  • The calling Flow, API, agent, or nested tool must provide its own connections.
  • If overrides are not supplied, execution fails.
Connection overrides are mandatory, even when a tool is nested inside another tool.
This design ensures:
  • Secure credential handling
  • No shared connection leakage
  • Reusability across environments and accounts
Use an API builder when
  • The process must be exposed externally
  • You need a REST endpoint with URL, method, and headers
  • You must customise success or error responses
  • A strict 2-minute synchronous execution is acceptable
APIs
  • Have one request and multiple response nodes
  • Always execute synchronously
  • Do not support internal retries
  • Enforce a 2-minute timeout
Caution
API calls are billable. Avoid using APIs for internal reusable logic when a tool is sufficient.
