This flow syncs NetSuite subscriptions as Salesforce custom record subscriptions. When subscriptions are added/updated in NetSuite, this integration flow exports subscriptions from NetSuite subscriptions to Salesforce custom object subscriptions.
Flow details
- Export source: NetSuite
- Built-in Listener: Get NetSuite subscriptions - get all subscriptions from NetSuite.
- preSavePageFunction hook: Processing NetSuite subscription.js - normalize data for line item fields.
- Built-in lookup: Get NetSuite price plan by ID - get all price plans from NetSuite by subscription line ID.
- Import destination: Salesforce
- Built-in import: Import Salesforce subscriptions(custom record) - add or update subscriptions into Salesforce with the configured custom field as the lookup identifier.
- Built-in input filter: Import Salesforce subscription lines (custom record) - filter for subscription ID record that is not empty.
- Built-in import: Import Salesforce subscription lines (custom record) - add or update subscription lines into Salesforce with the configured custom field as the lookup identifier.
- Built-in import: Import Salesforce price plans (custom record) - add or update price plans into Salesforce with the configured custom field as the lookup identifier.
- preMapFunction hook: Processing Salesforce priceplans.js - normalize data for price plans fields
- postResponseMap hook: Processing Salesforce price tiers.js - normalize data for Price tiers fields
- Built-in input filter: Import Salesforce price tiers(custom record) - filter for price plan ID record that is not empty.
- Built-in import: Import Salesforce price tiers(custom record) - add or update price tiers into Salesforce with the configured custom field as the lookup identifier.
- Built-in input filter: Import Salesforce NetSuite pricings(custom record) - filter for subscription ID records that are not empty.
- Built-in import: Import Salesforce NetSuite pricings(custom record) - add or update NetSuite pricings into Salesforce with the configured custom field as the lookup identifier.
- preMapFunction hook: Processing Salesforce NetSuite pricing.js - normalize data for subscription line field.
- Built-in input filter: Import NetSuite subscriptions - filter for custom record that is empty.
- Built-in import (Salesforce Id write back): Import NetSuite subscriptions - update subscriptions into NetSuite with ID as the lookup identifier.
Notes:
- This flow supports single and multiple price intervals in NetSuite subscriptions.
- This flow supports single price intervals in NetSuite subscriptions.
Before you begin
- The items should be present in both Salesforce and NetSuite.The NetSuite item ID should be stored as a custom field in the Salesforce item.
- The NetSuite customers should be present in Salesforce accounts. NetSuite customer ID should be stored as a custom field in the Salesforce account.
- The NetSuite billing accounts should be present in Salesforce billing accounts (custom record). NetSuite billing account ID should be stored as a custom field in the Salesforce billing account.
- The price book, initial term, subscription plan should be present in both Salesforce and NetSuite.
Setup instructions
- Configure the following dynamic mapping according to your business requirements in Import Salesforce subscriptions (custom record), before running the flow.
- Configure the dynamic mappings according to your business requirements in Import Salesforce subscription lines (custom record), before running the flow.
