Set up a connection to xAI
xAI is an artificial intelligence company focused on building advanced AI systems to understand the universe and accelerate scientific discovery.
Setting
Instructions
Name your connection *
API type *
Choose your xAI account API type:
  • Inference: Run AI models to generate responses, analyze data, and power applications with real-time intelligent outputs.
  • Management: Manage API keys, access, usage, and configuration to control and monitor your xAI integrations.
Inference API type:
Inference API key *
Enter your xAI account API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text.
Management API type:
Management key *
Enter your xAI account management key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s key safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the management key
How to retrieve the API key
  1. Sign in to your xAI developer console.
  2. Navigate to API keys > Create API key.
  3. Enter a Name.
  4. Select a Restrict access.
  5. Select a Customer rate limits.
  6. Select an Expiry date.
  7. Copy the API key.
  2. Navigate to Settings > Management keys.
  3. Click Create management key.
  4. Enter a Name.
  5. Select the Endpoint group access levels.
  6. Select the IP address.
  7. Copy the Management key.
Additional references
