After connecting an MCP server, you can monitor your MCP usage and request add-on entitlements if you’re running low. An MCP call is counted each time a tool, prompt, or resource is invoked through the MCP server.
You track your MCP usage directly within the platform to understand how frequently your MCP server is being utilised.
Tracking usage helps you:
Monitor consumption against your entitlement
Identify high usage tool, resources, and prompts
Plan for additional capacity if needed
MCP call behaviour
Every invocation of a tool, prompt, or resources count as as one MCP call
Calls are counted regardless of success or failure
Usage is aggregated across all MCP servers in your account
Usage limits and notification
To ensure your integration continue to run smoothly:
The platform does not block MCP calls if you exceed your entitlements
You will receive email notifications when you are:
Approaching your limit
At your limit
Exceeding your limit
This allows you to action without interrupting your business process.
Request additional MCP calls
If your usage is consistently high, you can request for additional MCP call entitlements. To do this, contact your account representative or Celigo support to:
Increase your MCP call limits
Explore add-on packages
